Indexmill
Hi,
I am restoring a Proto 1/4" pear head ratchet, # 4749. I would like to replace the two flathead screws with new ones. So, I dissassembled the ratchet. The two screws were hard to start to loosen but came out fine.
However, it looks like the threaded holes in the plate are 2-56 and the actual screws are 4-40. A new 2-56 goes into the plate perfectly and tight; the screws go into a new 4-40 nut fine. The threads on the ends of the two screws that had gone into the plate are clearly deformed.
The head of a new 2-56 flathead screw nearly goes right thru the countersinks in the body of the ratchet so I really don't think a standard 2-56 flathead screw is correct. And a new 4-40 flathead screw will not come close to starting in the plate holes.
I wonder if anybody can look at their 4749 and report what you find. It seems fascinating to me that Proto could have done this by design.
Many thanks for any input on this.
John.
John.
