MatBirch
I’m looking to design and fab a table leg set, or prop to hold the end of a platform. (Think supporting the end of a bedslide). It will need to hold maybe 80-100lbs. Trouble spot is that it will be camp trailer, so It will need to be able to quickly adjust to uneven ground. A simple inner/outer tubes with a welded nut with a thumb screw would work, but I doubt it would hold the weight without slipping, unless the the inner leg was tapered.
Maybe the guts of a pipe clamp??
How tough would a collar clamp like a painters extension pole be?
Any ideas?
Thanks!
Any ideas?
Thanks!
