Quick and easy lighting layout question
Flamario
Using the Visual Interior tool with the "MRSL L48 5000LM FST MVOLT GZ10 30K 80CRI MS1" product I get a populated layout (see picture below).
I use my garage for automotive repair, and the occasional full paint correction.
So for the quick and easy question.. should I hang the lights at the orientation shown from the populated layout? Or should I move them 90 degrees and use that one? (see picture below)
I have already purchsed
LED Housings: (x15) Maxlite LSS2XT8USE4803
LED Bulbs: (x30) GLLUSA GL07103-3M(5000K) 48" 18W LED T8
I've been a long time browser on this forum, and have gone through Platonic Solids threads in their entirety multiple times.
Thanks for your help.
Platonic Solid
CT-USA
Parallel to and in-between cars.
Or something like below: (except with 15 fixtures put 3 in each row and column. Note: fixtures are 2ft from walls to get light between cars and walls)
Here's a layout based on 4ft strip lights from post 1 of best light fixture thread.
Space is assumed to be 20ft square, 9ft ceiling. Click on image for larger view.
Here's the Dialux report (link).
F
Flamario
I wasn't expecting such a speedy response, so for that I'm greatly thankful.
What sort of spacing should I have between the rows and columns?
F
Flamario
To answer that question would require actual work which I don't have time for right now.
Completely understandable, your threads have been help enough.
I'll work off of what you said and will post up pictures when I finish this weekend.
Platonic Solid
CT-USA
Here you go: Dialux Report (link). This is about as even as I can get with 15 fixtures and maintaining shadow free with 2 cars in the garage. Fixtures are 2.25 ft from walls. You will have bright spots on the walls, but that's the sacrifice you make for lower ceiling and no shadows.
F
Flamario
Installing the lights now. Thanks again for the layout.
