Quick coupler of choice
Sumboodie
AK
Why didn't you run your main line in the corner? Would have saved a fair bit of tube it seems?
The ones I use have an "OSHA" coupler so you have to slide back a ring that is a valve. It makes hooking and unhooking tools much easier since there isn't any pressure against the coupler.
T
thejudges69
youngstown, ohio
My compressor is dead center of the doors, this was the simplest cleanest approach with the 6 branches to the walls, essentially I have one main line front to back in the center of the garage. My old shop was a loop system but I had steel trusses to contend with on that shop and didn’t want air lines free hanging.
dnschmidt
Phoenix, AZ
Milton is a catalog company. They do not design or manufacture anything and never have.
The so called V style standard was created by CEJN a Swedish company.
Completely true but also completely irrelevant as in American this type of fitting, deservingly so or not, are commonly referred to as Milton V although they did nothing whatsoever with respect to designing them. As Jimmy Carter correctly noted: "Life is not Fair."
u2slow
BC
I started with M fittings because I didn't know any better.
My big impact gun never punched very hard, so I tried P/T fittings (3/8") and that made a huge difference. A little tough/obscure fitting to find though... then got to the V which flows almost as much, and offers M compatibility.
When I started hard-piping the shop, I went with G type (1/2") to jumper my portable compressor to the fixed piping.
crazylunker
Connecticut, Trumbull
I’m sorry guys, not starting a ******* contest, but my dads 82 years old and still connects and disconnects his old Milton’s with ease. I watched some of the stedlin YouTube videos, and good lord, if you could dramatize it anymore. Are they good connectors? Idk, cause I don’t own any. But based on them videos 😂. I’m happy with my purchases of Dixon.
you are right on the old miltons. I have 2 bad shoulders and was having trouble pushing the newer style (push connect) couplers together.
I have the T style male fittings on everything and recently bought some of the old school female couplers where you have to slide the collar back first, OMG I forgot how easy they are to connect even at 170psi.
needless to say I'm swapping all the female couplers back to the old style.
