quick disconnect for grease hose?
lightning02
does anyone know where online i can buy quick disconnects for grease hose? basically the same thing like you would use on a air hose but made for a grease hose? i want to be able to remove mine and gun for easy of storing and moving since i have a 75ft hose.
links if you have.
Snakebyt
Lubbock Tx
Ahhh.. that makes more sense, While i cant help you out, i have seen one on a grease gun in the past, but this was years ago and the gun was no telling how old.
crane operator
sw missouri
I would think you would be better off with a set of hydraulic quick disconnect hose couplers, rather than air hose connectors.
That way when you unhooked it wouldn't be leaking grease out the one disconnected end.
Go to a hydraulic shop and pick what you want.
WWheeler
Middleofnowhere USA
This. Should be able to stop in any hydraulic supply and explain what you're wanting to do.
If it were me if I could I'd take the hose off and take it with me to show them exactly what threaded ends I needed the couplers to have.
L
lightning02
ok ill give this idea a try.
pete379
i made a hose hanger (like garden hose,but smaller) hang on side of the quarter drum (120 lb grease)
