Quick Jacks on RACEDECK Floor
RaceDeck1
Salt Lake City , Utah
I got a set of QuickJacks and they are such a great addition to the garage! ( and the track). Really easy to setup and use, plus they are portable so you can use them in the garage, the driveway or move around to other locations easily.. Highly recommend.
sps4runner
southeastern Mass.
I had a set of Quickjacks already that I had been sliding around on the bare concrete floor to position them; difficult to slide.
Just installed Racedeck. Hadn't thought about it but should be much easier to place the Quickjacks now!
R
RaceDeck1
It works fantastic on top of RaceDeck, very easy to slide into place and stable when the cars are lifted -I plan on getting their wall mounts too! great company to work with.
Streetscapetv
SLC, UT
I have been lurking here for a few days and had to make an account to give props on that car, especially since you're local! I hope to have a garage like that one day!
pepi
Woodstock, GA
Just a heads ups, you may already know this. Suggest you check the air pressure of the slave cylinders. Before using, as part of the set up, preflight.
That helps the jack retract fully after the car weight has unloaded, sitting on the tires.
Found a ram would loose all pressure in a day or two. Gave the schrader valve 1/2 turn, ended up removing the chrome housing. Wrapped the threads with teflon tape, good to go.
That's quite the hotRod ya have there.:3gears:
Love the Quick Jack very nice and well built, I don't find them hard to slide around on a concert floor, might be for weaklings .
pepi
Woodstock, GA
