Quick question/acid etch
Wycked304
Atlanta Suburbs
So I went ahead and purchased a Master Kit from ArmorPoxy. Everything came neatly packaged with everything you could ask for. I did my initial prep Saturday(filling cracks and sweeping out everything) and last night I did my acid etch. So, here is my question. I diluted the etch and poured it down and let it sit for a few then scrubbed with a stiff bristled brush, then pressure washed the entire surface. The spots where the acid wash actually hit the floor first are a much brighter white than the rest of the floor. Should I be concerned to the point that I should go buy more and try to saturate the entire surface with acid so that it can do its job, or was my initial pour, scrub, pressure wash process sufficient enough? Thanks in advance for any and all suggestions/help.
W
Wycked304
Atlanta Suburbs
Sorry, I left that out. I did an initial rinse scrub with just water, and then went back with the acid while the floor was still wet.
Armorpoxy
We don't see any issue, as long as the floor was etched per the instructions it should be fine.
