Quick question on flanged bearing replacement
Hi all,
I've just run into the first time I've needed to replace a roller bearing. This is on a wheel for a hand truck.
I can see the bearing number is 6202Z. However, the existing bearing clearly has a "lip" or flange that allows it to be seated correctly in the wheel housing (see the attached photos). When I search for the 6202Z bearing, the photos do not show this flange. For example:
https://www.amazon.com/dp/B00FH4ADLU/?tag=atomicindus08-20
What gives? Why does the same 6202Z bearing number not have a flange like the one I am trying to replace?
Hi all,
