Quick question on T-track bolts
oldpops
Southern California
Hello all! Everyone here has always been both knowledgeable and helpful in the past. So I am hoping you folks out there can help me answer my question on T-track bolts. I have a section of T-track, and some 1/4x20 hex head bolts that slide back-and-forth in the t-track just fine (and don't come out). I also have a mounting bracket for a custom tool that I would love to mount on the t-track, but the diameter of the (thread section) of the 1/4x20 bolts is too big. I really need to find some bolts or machine screws(SAE or Metric) where the thread section is smaller in diameter than the 1/4x20 bolt, but that also have a head that is big enough so that it will NOT come out of the t-track. Being disabled it is very difficult for me to drive to a big-box store to spend some time just fitting the different size bolts/screws to see what would work. However, since I can't do that, I am hoping someone here can offer some help or advice on what screws or bolts have a head big enough to sty inside the track, but also have a smaller diameter thread section (than the 1/4 by 20). I have even thought about using a smaller screw/bolt than a 1/4x20, along with a flat washer that will fit in the T-track section,so that the smaller bolt head won't come out of the track opening. Then use another flat washer and nut on top (to hold the smaller screw/bolt in the t-track). However, I don't know the sizes of the washers that would fit, or of the screws/bolts that would fit/work. Once I know that I can just get them online. As always, all help & advice is greatly appreciated!!!
mikegt4
sw ohio
Are you talking T-track like this? If so woodworking places like Rockler and Woodcraft have it. Be aware that often there is sometimes a slight difference in dimension to prohibit co-mingling of brands just like in the aluminum extrusion (80/20 etc.) industry.
seber
Deep East Tx.
Most t type tracks use special nuts. In any case, the manufacturer if the track is an important factor. We could help more if we knew that.
GeoBruin
What about going down to your desired bolt size and using a small washer on the bolt head to mimic the size of the 1/4-20 bolt head? Since the head of a smaller bolt will also be thinner, there should be room for the washer as well.
rharman
SoCal
Have you considered using a fender washer and cutting/grinding flats on two edges?
Or, cut a small rectangle out of 1/8" aluminum bar stock and drill/tap it?
LeeG
Phoenix, AZ
How many do you need? If it is just a couple, it shouldn't be all that hard for someone with a lathe to make some out of some hex stock.
O
oldpops
Southern California
Hi everybody, and thanks for the help. I should have mentioned the t-track that I have is POWERTEC 7119 Double cut universal t-track, (see link: https://www.walmart.com/ip/POWERTEC-71119 - Double-Cut-Profile-Universal-T-Track-with-Predrilled-Mounting-Holes-2-Pack-36/233630003 ). I think going down in bolt size and using a small washer (that will fit in the track) is probably the best idea. I just haven't been able to find a bolt and washer combo that will fit inside the t-track grove. I know that the max width of the t-track groove is 9/16th's of an inch wide, so I imagine a washer that is 1/2 inch in diameter will work. If anybody has used other, smaller bolts and washer combinations in their t-tracks, please let me know(what size bolts & washers) worked. Thanks
Git
S Cal
What size bolt will actually fit through?
There are T Bolts and there are also 'hammer head' bolts that may work for what you want. Example = M5 Hammer head, which is smaller than 1/4"-20, is about a 10-32.
With Amazon's 'free returns' all you have to do is drop it off at a UPS store or Kohls to send them back if they don't work (although they only cost $12 for an assortment)
MoonRise
Folks, he said (typed? :lol: ) that the 1/4-20 bolts fit just fine in his T-track.
His issue is that the 1/4" bolt diameter doesn't fit into the mounting holes on a bracket for something that he wants to mount TO the T-track.
So, my first thought would be to enlarge (drill out or maybe just use a "tapered reamer" if the bracket material is thin enough that the taper from the reamer isn't objectionable) to clear the 1/4" diameter.
Got any pictures of your mounting bracket?
Moving up in effort would be things like making an intermediate bracket that mounts to the T-track and your bracket then mounts to that intermediate bracket. Or making some sort of custom nut or bolt that can mount everything together.
Can you step down to a 10-32 bolt and fit thru your bracket? You might find 10-32 t bolts, but here is a T Nut, you could Loc-Tite a stud in it if needed.
O
oldpops
Southern California
You folks have all been fantastic!! Both the M5 & M6 hammerhead bolt idea, and the 10-32 bolt/screw are interesting. I will check out these ideas and suggestions and report back. Thanks again to all who offered help and advice!!!
  • Like
Reactions: RTM
Leaflessshadetree
Don't ask.
I have T tracks on my boat that I use carriage bolts in. (I can't seem to find affordable T bolts that fit).
I modify the carriage bolts by grinding 2 sides of the head off. I see that other guys modified the track so teh head slides in.
