Quick question re: conduit box hole ID
TT_Vert
Wauconda, IL.
I accidentally knocked out the larger part of a 1/2" knockout while trying to get the 1/2"er out. So now I need go get reducing washers. My question is, is the washer based on the ID of the hole? The reason I ask is that the ID is 1 1/4" but it seems HD stocks the 1" to 1/2" but none of the 1 1/4" washers which leads me to believe the 1 1/4" is not that common, so I want to confirm these washers need the ID of the hole that it needs to reduce? If so I'll just order some 1 1/4 to 1/2" reducing washers unless anyone knows other places that may stock this size. Doesn't seem like lowes or menards does either.
Thanks
Dave
engineer2
Chicago burbs
Household electrical boxes generally have knockouts for 1/2" and 3/4" fittings. If that is the case you would need a 3/4"-1/2" Reducing Washer - Menards # 365-1058
Curious: Are you metal conduit or Romex? I seem to recall Wauconda and/or Island Lake allows Romex.
T
TT_Vert
Wauconda, IL.
It's not a 3/4". I have one hole w/ a 1/2" | 3/4' knockout and the other is 1/2" | 1" it appears after looking at the NEMA specs for nominal ID of conduit fitting holes what I have is a 1" (NOT the 1 1/4" I assumed based on the ID of the hole) knockout, i just couldn't measure the ID precisely w/ it in the wall. I'm all conduit, this is newer construction. Fortunately this entire house is conduit. I did run a few short BX whips for some additional lighting but it's all w/in code.
Dave
engineer2
Chicago burbs
You might need a 1"-1/2" Reducing Washer - Menards SKU: 365-5711
Lots of good electricians here at GJ. I'm sure they'll be chiming in when they get off of work.
mm08822
They are spec'd by conduit size. Knowing the ko diameter is needed to figure the conduit size if you cant tell by eye..........
1/2" c = 7/8" hole
3/4 = 1-1/8"
1" = 1-3/8"
etc..............
