Quick questions on wire size and associated greenfield size
olytdi
Olympia, Washington
Quick questions for the electricians in the group:
Wiring a 12 KV electric unit heater. I understand that I need #4 copper from 70amp 2p breaker. What is the wire gauge needed for the associated ground? Can I use #8?
Will I need 1 inch greenfield for that run of wires or can I fit it in 3/4 inch?
Thanks up front -- I appreciate the shared knowledge!
Wiring a 12KV electric unit heater. I understand that I need #4 copper from 70amp 2p breaker. What is the wire gauge needed for the associated ground? Can I use #8?
I assume you meant 12KW... you need 62.5a rated wire.... so #6 THWN will work (good for 65a).... ground wire would need to be #8...
might be kinda tight fitting that in 3/4"... i would go with 1"
O
olytdi
Olympia, Washington
Thanks Wylie! Yes! I meant KW! LOL.
I thought it was #4 -- #6 just means more savings! Thanks for confirming the #8 ground and the greenfield size!
O
olytdi
Olympia, Washington
3/4" greenfield is fine. NEC limit is four #6 thhn in 3/4". I assume this is a short whip?
So the manufacturer's website states #4 for this heater and a 70 amp 2p breaker. Any idea why that differs from the recommendation here? I already have the breaker -- 70 amp would require the #4 wire correct? I think that they're accommodating the 80% rule(?).
12KW / 240v is 50a. 50a x 125% = 62.5a wire.... #6 is good for 65a but the manufacturer is basing their wire size off breaker size.... 65a breaker is not a standard size and code allows you to use the next standard size as long as the load doesnt exceed the wire rating, which it wont....
mm08822
The conductor ampacity needs to be 50a x 125% = 65A.
Mfr probably assumed worst-case use of 60C rated wire (NM-B) and #4 copper is good for 70A.
If you use THHN/THWN, rated for 75C (in this case) #6 copper is good for 65A.
The 70A cb can be used in either case.
O
olytdi
Olympia, Washington
Okay, thanks! What I hear you saying is that for 12000 watts, I can use #6 THHN/THWN and use a 70 amp breaker.
O
olytdi
Olympia, Washington
