I have a few rotted poles in my pole barn ... and am considering pouring concrete piers and sinking some W6x15 steel beams to replace them.
Just to be sure, I am comparing the compressive axial load of the two and making sure my instinct (that the I-beam is *much* stronger than the 8x8 doug fir timber) is actually correct.
So, I see on this page:
http://www2.wwpa.org/portals/9/docs/pdf/tn9.pdf
... that a doug fir 8x8 with length of 16' has a compressive axial load of 33801 lbs. Then I look on this page:
http://www.webcivil.com/usaxialw.aspx
(and I select W6x15 from the designation pull-down, and then click "apply" button in the upper-right) ... and I see that a 6x6 I-beam of 1/4" steel has a compressive axial load of 147 kips, or 147,000 lbs.
Does that all sound right ? The 1/4 steel 6x6 I-beam is about 4-5x as strong, vertically, as the 8x8 ?
Are steel beams just so much stronger than (roughly equivalent) wooden beams that it was silly for me to compare these in the first place ?
(FWIW, I will dig the piers down 5 feet, pour a foot of concrete for a solid footer, place the I-beam in, and then pour concrete to surround it for the next four feet to ground level ... so replacing a 16' 8x8 timber with a 12' 6x6 I-beam. I think this is probably total overkill.)
Thanks.
Thanks.
