Quick Trailer hub question
oldpops
Southern California
Just a quick question on putting grease inside a trailer hub: Do we fill the entire cavity around the spindle, between the inside and outside bearings with grease? On the hub I have now there's about 3/16th of an inch space around the 1" inch straight spindle on our trailer/cart. Of course the bearings are both packed and the spindle itself is completely covered, especially where the bearings ride, but I wondered if I should jam some grease in there to completely fill the last little bit of the cavity inside the hub? I don't know how that would benefit the bearings since they ride on the spindle and bearing race, so is more grease a waste of time? Doesn't matter to me but since I've never done a trailer/cart hub install I thought I would ask you folks here. Any and all help, advice and suggestions is extremely appreciated.
cannuck
Rural SK
You can easily get decent service out of bearings that are packed properly witout stuffing the whole hub (questionable if the grease in the middle will ever contribute much to the actual bearing lubrication). However, if this is a boat trailer you really DO need to completely fill the hub. To do that you buy a "bearing buddy" hub cap with spring loading. You fill the hub best you can while assembling then use a grease gun on the Bearing Buddy to fill any spaces and charge the preloading spring.
juddspaintballs
Hedgesville, WV
I pop the caps off my trailer hubs and squirt grease in the zerks before I take it on longer trips. I built the trailer in 2014 and I'm still on the original bearings.
PoorUB
Fargo, ND
If you maintain the bearings they will last forever.
I have a trailer I built in 2000. I t got used short trips and then I needed to drag it about 2,000 miles. I decided I should repack the bearings as they had not been done since I built the trailer, so 20 years. The inner bearings had gotten a bit of moisture in that time so I replaced them, the outers looked fine and I put them back it.
On a different note, I had a 1974 Monte Carlo. When I got rid of it it had 250,000 miles on it and the original front wheel bearings. I did repack them every year or two.
yatg
Southern Oregon
Carry a couple of extra dust caps or rubber plugs (ez lube axles) with you. Never know when you're going to lose one followed by all the grease slinging out.
Jinks
Daytona Beach
Depends on what you use the trailer for. I used to work with a couple of know-it-all rednecks. I was planning a trip & towing a trailer. They asked when was the last time I packed the bearings on my trailer. I told them either last year, or the one before. Both went ballistic & went into rants about how I needed to clean & repack bearings after EVERY use of the trailer!!! I let 'em rant until they ran out of breath, then I told 'em "I know you do that with your boat trailers, but I almost NEVER load or unload my MOTORCYCLE in a river or lake". It's amazing how blank an "expert" can look.......... :lol:
:lol::lol:
PoorUB
Fargo, ND
Who the hell does that, even on a boat trailer??
When I had a boat I repacked them every fall when I put the boat away. Even I admit that was more often that needed, but I never had a trailer bearing fail!
RaisedByWolves
SE PA.
I think the real issue with boat trailers is putting the trailer into cold water when the bearings/hubs are warm and on seals with lots of use on them.
Just going 6" under water alone is not enough change in pressure to cause water to seep in if everything is in good order, but putting a 100+ degree hub into 40 degree water might cause issues.
YMMV
Leaflessshadetree
Don't ask.
YMMV
Actually the rapid cool down as the warm hubs are dunked in the water causes a pressure change that can **** the water in.
cannuck
Rural SK
I build some medium duty and operate some heavy duty trailers that put on hundreds of thousands of miles - all oil flooded hubs. The HD stuff can go the best part of a million miles on the very conservatively sized bearings, but the farmyard garbage (typically Dexter) axles on smaller stuff have bearings far too small for really long service and usually fret the spindles to a point where they are under diameter where the inner races fit. Light duty stuff has small bearing compared with axle ratings, but most of those trailers are seldom loaded to limits and don't see much mileage, so can last a fair bit (I have gone up to 40 years on one I can attest to and have another with at LEAST 60 years of grease packed service, but doesn't get used much any more).
nh_yota
Seacoast New Hampshire
:lol::lol:
What a bunch of BS
firebirdparts
Kingsport, TN
Well, let's face it; nobody anywhere thinks you repack a bearing everytime you turn a tire. These were shockingly absurd people.
RaisedByWolves
SE PA.
Hell you say!
I tore my truck down right after parking it in the lot at work this morning and repacked the muffler bearings and changed the blinker fluid.
I plan on checking the ring gear clearance front and rear before driving it home. I’ll do the same tomorrow morning before making the arduous 5 mile trip to work.
Can’t be too careful, don’t want to get stranded in the suburbs.
Monza Harry
Windsor ON
Wheel bearings on my truck [Sonoma] went 100,000 miles, I bought replacement bearings as "Preventative Maintenance" for that brake job [integral hub/rotor. Old ones still looked perfect, cleaned and left in my spares for "just in case". M0aintained they are nearly bullet proof. Bearing buddies are useful for not often used trailers, a squirt and go if you are going some extended distance, to make sure the existing grease isn't petrified so they aren't used dry. Full for dry use will cause issues, like oil being thrown out of the hub (as the bearings warm up to operating temp). "EZ-Lube" axles put the grease in a better place then the BB's, but any grease is better than no grease, any day. Harry
