I've been cooling my ~1000 sq-ft house with three window A/Cs totaling 16k BTU for the last 15 years. Biggest is 6000 BTU for the main living area. Other two are 5k; one each in 145 sq-ft bedroom and "office". More than enough even on days when temps and humidity are both high 90's. It gets hot and humid here in July-August.
For a 130 sq-ft room, 8k is
way too much, especially with updated windows and insulation. I think it will short cycle and - worse - not remove the humidity because of the short run time. The room will be cold and clammy.
The remote control is nice, but overrated. Automation is better. I use
LUX WIN100 5/2 programmable line-voltage thermostats to run my A/C's on a schedule. They are about $30 and work like a charm. I also use them in the Winter for space heaters, and I use one in my garagement/barage to shut off a dehumifier below 60°.
They also work better than even the fancy window A/C thermostats because they have some separation from the window units.
