i am wrestling with this same problem. rust can definitely prevent the Quickjack from lowering. i made the mistake of working on a salty dripping car in December and not cleaning the jack afterwards. last week i put a VW Golf on the jacks doing some maintenance. when i went to lower the car the right jack frame would not lower more than an inch. after considerable time on the phone with Quickjack they determined that i needed to remove the car from the lift in order to determine if it was rust on the pivots or a defective cylinder. i used a floor jack to lift the car onto jack stands. once the frames were removed from under the car and the cylinder was disconnected the frame would not lower. now i could see that the front bottom pivot was severely rusted. the 3 other pivots were moving freely. i have been soaking the pivot point in Evapo-Rust hoping that will help free up the pivot. i don't have a tractor and truck available to try your method so next i am going to try soaking it in oil for a couple of days, if the Evapo-Rust fails, then maybe ratchet straps. the Quickjack solution was to buy a new frame for $1175.
