I'm looking for some advise on compressor selection. I'm trying to downsize from a big (and entirely overkill) three phase Kaeser screw compressor to a less expensive piston compressor.
My needs are fairly modest: I reckon that 3 hp (at 240V, naturally) would be sufficient but wouldn't mind having 5 hp. The primary use will be running the ATC and mist coolant on a small CNC mill with the secondary use being general air tool use (i.e. blow gun, occasional die grinder, occasional air hammer, blowing out sprinkler lines, filling tires, etc.). The compressor will see intermittent use, maybe a handful of hours a week on average; it won't be running constantly in any respect.
My only additional requirement is that it be relatively quiet. This is quite important as the compressor will be in a fairly small shop that's acoustically quite loud. I figure that with my low air usage requirements it'd be possible to find something suitable. I'd like to stay under $2000 if at all possible, and cheaper than that wouldn't be a bad thing!
If you can help point me in the right direction I'd appreciate it!
