Quietest 240 volt garage heater
Mike99
Can anyone recommend a good and quiet heater for my 500 sq ft insulated shop? Im considering a 7.5 kw unit heater for quick warm ups although 5kw would probably suffice.I find my 240 watt construction heater which I occasionally use in the basement to be a little loud.
yeldogt
They all make some noise .. the higher output units I have encountered do make more noise.
I have two of the Qmark 220v heaters in one if my spaces -- one is a QPH4A 4000k/2667K the other is the common 2k/1.5k wall unit. They both have two output levels as well as a thermostat.
Electric baseboard is completely silent and is easy to control with a 220v wall thermostats
nh_yota
Seacoast New Hampshire
Are you going to keep the heat turned on at some level all the time? Baseboard heaters work fine if you're only going to set the heat back to 55 or 60 then crank it up when you're in the shop, but if you're going to turn it all the way off you need something with a blower.
Falcon67
Merkel, TX
Fairly quiet, works - G73, 5kW. Throws air a good distance, works well for 672 sq/ft after a bit, will run you out of 240 sw/ft. Was the only heater in my old 480 sq/ft shop.
ForceFed70
BC, Canada
Wattage is wattage regardless of a blower. It won't impact warmup time or anything like that. Hot spots can become a problem, but remember that a 2500W 240V baseboard heater is about 8' long and does a decent job of distributing the heat. A ceiling fan or 2 would resolve any hot spotting concerns and comes in handy for other purposes as well.
nh_yota
It makes a difference from a practical standpoint. Passive baseboard heaters take up wall space, and if he wants the shop to heat up faster he will need more wattage, which usually requires longer baseboard heaters that take up more wall space. A forced air unit heater can provide more wattage of heat in a smaller footprint, so to speak, so he won't lose wall space for cabinets and stuff that you wouldn't be able to park in front of a baseboard heater.
ForceFed70
BC, Canada
Yes, anything without a blower will be physically larger. Anything with a blower is going to make noise. Tradeoffs.
I had no problem locating 2 x 2500W baseboards in my shop. Tho they're just installed as backup heat anyway - my primary heat source is a NG unit heater.
Cruzan80
Denver, CO
I got the one like pictured above from ruralking, fan cna get a bit noisy on full, but nothing loud. Easily talk and listen to music over it.
Falcon67
Merkel, TX
Also consider that when the temp stabilizes, the fan is only going to run once in a while. In really cold - like 30s~20s here - mine might run 15 minutes of every hour.
ErvinBurns
Lasko Silent Heater is a good option and it comes with a digital display. It is a 1500 watt convection heater and uses natural convection to circulate the air without making any noise. It will shut off automatically to prevent overheating, and it also has a safety switch if it tips over. If you prefer personal heater then you can try out Vornado SRTH.
