Quieting ABS pipe...
tarmy
Nor Cal
I have ABS on the second floor running in between the floors...noisy down stairs...
I have plenty of room to add several solutions like extra insulation, spray foam etc....
Any suggestions are welcomed to help quiet the water flowing noise...thanks
Milton Shaw
A lot of two story houses have cast iron pipe in the ceilings of the first floor because the plastic is so noisy. I don't think insulation will get it that much quieter.
Norcal
Swap out the ABS for cast iron, but that is not always feasible.
Stuart in MN
Minneapolis
I'd look at wrapping it with sound deadening material. In cars they use Dynamat or similar products, but for home use try that peel and stick rubber roofing stuff you can get at the big box store.
nh_yota
Seacoast New Hampshire
McMaster-Carr is a good source for generic sound deadening material. Anything with a brand name like Dynamat is going to cost significantly more. I looked into stuff like that 10-15 years ago when I was into car audio stuff.
rlitman
Long Island
Cast iron is by far the way to go.
The rubber stick on roofing in an interesting idea.
Wrapping in acoustilead should work well.
BD1
north side
Preformed pipe insulation is the first step.
Two Sheds
One of the cheapest things is to wrap it in a few layers of waffle carpet pad secured with cable ties. Get the heaviest and densest you can find.
Thumper68
Duluth MN
I replaced about 3 feet of cast iron with PVC in my basement workshop/office last week and I can sure tell the difference, noisy as hell now I may use one of these ideas to quiet it down.
rayra
Escaped from Los Angeles
Fiberglass batts or pipe insulation will do. Don't use a hard-setting foam, it will conduct almost as much noise as it attenuates.
Consider adding another layer of sound-blocking drywall.
/time warping to the days of Archie Bunker and Married With Children when a toilet flushing upstairs was a routine gag.
rharman
SoCal
When we remodeled 20+ years ago and added a 2nd story, the architects spec'd cast iron for the drops from the upper floor. I thought that was kind of old school until they explained the difference. Definitely quieter than what I've heard in other new construction that was all ABS.
kbs2244
A plumbing supply shop will have self-sick lead tape to run the length of your pipe.
It adds mass to absorb any vibrations.
It is code required in some places if you are going to be using C I soil pipe.
T
tarmy
Nor Cal
Excellent ideas...thank you for commenting...
I plan on implementing some belt and suspenders approach...probably go with split tube foam (insulation type)...with that lead wrap idea...I really don't have great access to all of it or I would do it right by going to cast iron...
