Quikrete coating question
Ulamph
Mt. Vernon, MO
Dear All,
First, love the site, helped me very much when choosing my coating as well as prep and application tips.
I finished coating my garage with Quikrete Epoxy Garage Floor Coating. I over prepped (as if there is such a thing) as, from what I read in here preparation is 90% of the job.
I applied the coating last Wednesday, April 20, 2011. I opened the garage door about once every 30 min. to change out the air for about six hours (till temperature got down to 60 degrees), then closed it up. I left for camping on Thursday and got home on Sunday. The floor is even with no color differences or stains, looks great and appeared completely cured. However, when i went to install the diamond plate molding I purchased, I noticed that areas that I sat on and slid across the floor appeared scuffed.
I went to a corner and found I was able to scratch the coating with a fingernail. I checked again this (Monday) afternoon and found that it still scratches. It does not chip or flake, just appears to be a soft surface.
Can anyone advise what this is caused by or if they have had that problem? Quikrete advises 2X stronger then concrete, however mine is not the case.
I also checked along the walls in various places, where i know the coating was first applied and also applied at the end of the can, thinking there may be a difference in the application time with no difference found. I used two sets of coating, with no difference between them found (both seem soft).
I did buy three sets (all tinted blue), and only used two, meaning I have one extra. I think the one will be able to cover the entire garage as i only used 1.75 to cover a garage a little over two. Will applying a second coat help? Also, can a second coat be applied over sprinkles?
I would really appreciate any advise you can give as I will not drive on it till I can figure it out.
Photographs (some don't show the blue well, cell phone camera and excessively bright lighting)
1) Scratches with fingernail (left couple was done on Sunday, single scratch done on Monday)
2) Scuff in the coating where I was sitting along the wall on Sunday.
3) Another scuff in the coating where I was starting diamond plate molding. The lighter scuff crossing the mark is from the pads of my fingers, when I first saw it I thought it was on top of the coating.
4) Larger area in center without scuffs)
5) Overview of area.
