Quikrete dumb questions
samptari
I'm looking to epoxy my garage floor, and bought the Quikrete kit. But I have a history of making dumb mistakes on home projects, so I thought I'd come here with some pre-install questions in the hope that this can go smoothly for me.
Some background:
The floor was new in 2007. There is some surface staining, but no major cracking. There is brand new concrete (poured a week ago) along the perimeter, due to recent foundation repair.
Here are my dumb questions:
1. How long do I need to wait for the new concrete to cure before applying epoxy? I've been told everything from 72 hours to 3 months.
2. Will there be an issue applying epoxy to a floor made up of both newer and older concrete?
3. Is there a prevailing opinion about the Anti-Skid additive? I think I'd prefer texture to ice-rink smooth, but does it increase the risk of chipping & peeling?
4. Since prep is 98% of a successful install, is what's included in the Quikrete kit enough, or do I need to do something in addition to their prep instructions?
5. What's the most important thing I need to do or not do?
Thanks!
nissan_crawler
Wichita, KS
i did valspar (now quikrete) on my 50+ year old floor that was covered in 2" of dirt, grease, and oil.
I spent 13 hours pressure washing (19x23), with 6 gallons of purple power, t boxes of tri-sodium phosphate, and a gallon of acid. I let it sit a week before I put the epoxy down.
It's still on there 8 years of hard use later. I put the first coat down, sprinkled anti-skid on top, then put a second coat on. The floor at work has no anti-skid, and if somebody so much as sweats on the floor, you'll split your sack walking across it. No thanks. I didn't use much, it's still not a big deal to sweep, and I clean up oil spills with blue shop towels with no problem.
I can't answer your question on concrete cure time, but I would be waiting more than 3 days for sure.
pima67
Tucson, AZ
I think that you should wait for at least 28 days for the new concrete to essentially fully cure. I used Quikrete color epoxy on the wide steps (3 ft & 4 ft) on two sides of my garage and used the clear kit on top of the color coat. The clear kit had a non-slip additive and it gives the floor a sandpaper feel (about a 60-80 grit). If your floor seldom or never gets wet, you may not need the non-slip additive.
mato
Cleveland, OH
28 days
No, as long as the newer concrete is fully cured and they are both cleaned and prepped
No, will not have any affect on chipping or peeling
I always say/recommend shot-blasting as best prep method, some don't want to go to that measure
I would say Prep!
Also, make sure you are fully mixing part 'A' and 'B' together, common mistake which could cause failure
