OverkillYJ
So my Quincy 310 ROC 22 is mounted on a 80 Gallon Tank with a 2HP 1250rpm motor. It runs hot, really hot if it doesnt get a chance to cool down. I am guessing something is wrong with the oil pump, but I cannot find any reliable info on how the oil pump is supposed to properly operate in the first place. I just rebuilt it. New race inserts, gaskets, valves, and piston rings.
If it runs say 20 min out of an hour it is fine like that all day. It is supposed to be continuous use 2stage. But now when I started media blasting with a 1/4" nozzle it started burning up on me and squeaking. The reason I rebuilt it was because of blown gaskets, but it ran fine. I am guessing things are getting so hot they started expanding from lack of lubrication? I dont think anything changed with the pump from what I rebuilt, I just never ran it like this before. I know in hte months before I rebuilt it it was getting warm enough from running a lot that it would heat the pipes and valve where I turn on my air lines that power my in ground lift and things. It is mounted over a bathroom so it is usually out of sight out of mind when it is working.
At this point I am thinking I need a newer pump to stick on top of this tank. Something that can run for hours without burning up on me. I am having a hard time finding anything I feel comfortable buying. I would like as many CFM as I could get without buying a new motor. So Whatever the best 2HP 1250 compressor is I should run? I have no idea.
I would fix and troubleshoot the oil pump if I could find detailed info about it before buying a new pump. Just taking it apaert though and figuring it out does not look like an option. It is a pretty complicated piece from the looks of it, and I do not know torque values or anything like that to properly reasemble it. I am guessing with the bearings and things in there I need to be pretty spot on or it will fail.
ANy help you guys could offer would be awesome. This forum always seems like a good place to start. I already have the schematics of the pump, and spoke with Quincy and two parts resellers. Apparently this Compressor built around 1962 does not have any real documentation for rebuilding, at least nothing for the public. They said the parts diagram whic is just bare bone schematics lacking even meqasurements of any parts is all there is. Because of that I did not mess with the oil pump at all when it was dissasembled. It is the only part I skipped. The pressure oil gauge is not reading anything at all no matter how much I adjust the screw in any direction etither.
I am doing my best to include any info you guys might need so I do not get answers like "go adjust the oil pressure". I have already spent hours playing with it from the outside. I do have all the O RIngs and things that came in the kit. if I knew how to safely take apart and inspect the oil pump for damage to repair I would do it. I am a technichian and this is actually easy to work on, but I know enough to know I need more info before I dive into the pump itself when I still have a pump that works fine light duty.
