gummycarbs
- Joined
- May 17, 2016
- Messages
- 21
Hi,
I picked up a Quincy 310 (ROC 21, L version) compressor pump awhile back and have been slowly getting it back into shape. It was the bare pump, so I'm assembling the rest of the compressor from Craigslist and Surplus Center.
My question is how to plumb the unloader. My understanding is that the Quincy hydraulic unloader provides two functions: 1) it relieves pressure on startup so that the motor isn't fighting tank pressure and 2) it prevents the compressor from building more than 40-ish PSI pressure in the event that the oil level is low. It's also my understanding that the design of the valves means that a check valve isn't needed between the output and the receiver tank.
I bought a Sunny 140-175 PSI pressure switch (4-1823-H4) with an unloader port. I also have a 3/4 check valve with a side port for the unloader.
Is there any reason not to use the check valve and the unloader port on the pressure switch? My thinking is to simply tee the check valve's side port and run it to both the pressure switch and the Quincy 310's hydraulic unloader. Any problem with that?
