bad_idea
I have an older Quincy 325 I pieced together for my home garage. It is driven by a true 5HP motor at ~900 RPMs. From Quincy's spec sheets, I see it is putting out 18.64 CFM at 175 PSI. Does anyone have the spec for what the CFM is at 90 PSI?
I am trying to size the maximum sand blast nozzle I can get away with on the unit. I sandblasted the floor pans in my jeep with it last weekend with good results. HF pot blaster with a 5/32 nozzle. Pressure switch on compressor is set to 80/125 psi. I have a regulator at the compressor set to 90 PSI. I did not regulate or monitor the pressure at the sandblaster. It performed well for about 45 minutes at a time, continuous. I am curious if I can up size the nozzle to use a coarser grit, or if I am at the limit now.
I am also toying with the idea of adding a second air tank (have it sitting around), and stepping the pressure switch on the compressor up to 175 cutout. Only reason the pressure switch is set to cutout at 125 now is because that is the switch I had laying around. I pieced this unit together with bits I had scrounged up/laying around. I understand higher pressure and larger storage volume will not increase compressor output, only provide a larger buffer to running out of air. Would the larger volume of air net me higher CFM output for a long enough time blasting to justify the effort to install another tank and pressure switch?
