Bigwheel74
Hi and this is my first post here so please bear with me. I have a Quincy 325 Roc13 that I picked up as a project and new addition for the shop. I just got it running and had no oil pressure. This has the vein type pump that can turn in either direction. I put a brand new motor, pulley, and magnetic starter on it as well and set it to spin ccw based on the arrow on the compressor pulley fan blades. When i run it CCW it doesn't build pressure. BUT will in the CW direction. By adjusting the pressure relief I get a quick 20 psi out of it. The problem I have or keep asking myself is that the direction of air flow across the intercooler isn't correct per my quincy service guy. To get pressure it had to pull air across the pump and intercooler. Doesn't seem very efficient and besides when I run it the other way it does push alot of air. The race that the oil pump veins ride in seems to be pressed into the casting and doesn't move. I thought maybe I need to flip the large pulley 180 degrees but the way it is now is how I took it apart. I also have a spare to look at and compare. If flipped I think there would be a clearance issue between the big pulley and intercooler. Not to mention the crank pto will most likely be recessed in that larg pulley. Let me know your thoughts. Thanks chad.
