WhoWhatNow
I needed a little help with the final stage of setting up my Quincy 325. I've got everything hooked up and the last leak is in the fitting that connects the unloader tower to the centrifugal switch. The parts manual says this should be a 1/4 OD tube X 1/8 NPT. It appears that someone stuck a compression fitting into the tower. The fitting does not tighten completely and leaks at the tower as well as the elbow. Is there any chance I will be OK simply getting the correct fitting or will I need to drill and retap the hole in the tower for a 1/4" NPT?
