Quincy 5HP 60 GAL Compressor
My Old Tools
Hamrick Lake, TX
That's a splash lube compressor very similar to all the other cast iron splash lubed compressors. It's not like the pressure lubed Quincy's. It's likely a step up from the store brands. It is US made.
63roundbody
I have that compressor. I use it for sand blasting, painting and tools. No issues or complaints. I've had it for 5 or 6 years. I don't have a magnetic starter (no need) and use a dryer.
Slednut
Washington state
My friend and I both bought that same compressor, his was fine mine had two leaks one was the plug in the bottom and the gauge on the pressure switch. They were both easy fixes.
We’ve both have used dual action sanders, die grinders and haven’t had any problems.
Sasquatch912
Georgia
Yeah, I saw about them pressure lubed ones, but they are $$$.
Which dryer/lube do you use? I know the PSI is rated for 175 and many dryers/lube set up only go to 150. Do you have a disconnect for it? Or you just have it wired to a 220v plug?
Glad it can handle that. Right now I am using the cheap 20 gallon Harbor Freight compressor.
Indexmill
Central NC
Are you certain that it is made in the USA?
HenryAZ
MEMBER EMERITUS
South Congress AZ
I've had my QT-5 (5hp, single phase, 23 amps, w/60 gallon tank) for 17 years. It has provided reliable trouble free service during that time. Last week the run capacitor failed. Replacements are due here tomorrow (I'm replacing both start and run, though the start cap reads within its range, but at the low end). The run cap is the only problem I've had with it. I'm taking the time while waiting to check motor internals, the contact plate and centrifugal switch. Getting the motor pulley off the shaft was a real bear. The whole machine was painted blue after assembly, apparently. The motor is Baldor, made in USA.
gatewaysysop
Arizona
And this is why I'm not a fan of Quincy anymore. Poor quality control.
Out of 3 compressors they sent to us, one was the wrong model and two were defective. One had a cross threaded outlet valve and leaked like a sieve, the other ended up being a sticking check valve. I've read enough accounts of newer Quincys leaking that it makes me think it's not a fluke. That you had not one but two leaks is par for the course, but at least it was an easy fix. Not a fix that the buyer should need to do on a brand new unit, but I understand it's probably easier than taking it back and trying your luck again.
When I had my issues way back when, I actually spoke to the product manager and QC guys at Quincy. They explained that they no longer had dedicated QC teams but instead "made QC the responsibility of each person assembling the unit", so that if they receive something not up to par from the previous assembly stage, they're supposed to flag it and send it back. The end result is exactly what you'd expect, that nobody wants to be That Guy™ who sends stuff back, so instead they just pass it through. Quincy claimed this was better because more folks doing QC than having a dedicated QC team, but I'm guessing it was just cheaper. :(
When their products work, they are fantastic. Getting one that works like it should, however, appears to be a roll of the dice. :dunno:
mike93lx
Richmond, VA
My experience on quality in manufacturing environments is the opposite. Stuff gets sent back all the time to earlier steps.
Sasquatch912
Georgia
So, should I look elsewhere? I am around the $1300 price range and I also need to get good suggestions on a good air dryer/filter system too.
gatewaysysop
Arizona
I hesitate to say, but I think this particular model is one of their bottom end units and, consequently, most of what you're paying for is the name. I am not 100% sure, but I believe the Quincy folks indicated that the pumps on these were USA-sourced but not necessarily made in-house by Quincy, as with some of their more expensive units (e.g. QT-5 and so on).
Just my $.02, but I think I'd at least shop around to see what specs you can get for the same money from someone else. I'm not trying to bash them, and I like that they are still US-made, but my $.02, for the premium price the QC ought to be better.
dnschmidt
Phoenix, AZ
Quincy's top of the line stuff is as good as ever. Their bottom of the line stuff (the models you're looking at) ****. I'm not insulting you but the cheap compressor that you're looking for (the price point you've picked is in the cheap compressor category) there are other brands that specialize in that area such as Campbell-Hausfeld, Belair (along with the seventy-five other brands that they manufacture for) that offer better quality for the buck than the low end Quincy's. I would look at the Polar Air (Eaton) compressors that you can get from the Home Depot.
vanapplebomb
Holland, MI
Similar experience with their newer economy compressors. It’s a cheaper compressor they can sell for good money because of the name. Same goes for IR compressors...their entry level 60-80 gallon compressors really do have poor pumps. The Quincy pumps are at least reasonable pumps, but the quality control on assembling the compressor is spotty at best. You have to pony up a good bit more $$$ for a good Quincy and IR. Sad that their consumer grade stuff has taken a turn for the worst the last decade or so.
matt_i
So to me the heart of what you are paying for is the motor, the compressor and the tank.
Leaks and component parts and wrong shipping are infuriating but once corrected are very small fry compared to above in my opinion.
I have yet to see a person say my Quincy grenaded when I plugged it in.
In my plant I bought a Quincy - 7.5hp splash lube 3 phase motor, about $250 more than the ones in this thread, out of the box and ran it on around a 98% duty cycle for somewhere around 2 weeks & 3 weekends. Straight. (24 x 16) = 384 hours straight without a break. It continued to run every weekend for the next year without any suggestion there was damage or degradation in performance. Basically just topped off the oil. I felt like their compressors and motors were pretty well validated as that was pretty abusive.
My personal compressor, IR-T30 is going on about 22 years old. Not run nearly as hard. Does the job well summer or winter, I turned down the pressure switch to 130psi as there's no need to run it up to 175psi.
Any future compressors (if ever needed) would be grey or blue. I would consider no others.
