Quincy Air compressor ID.
70 miles south of st.louis,Mo
I have acquired a Quincy air compressor that has no ID tags . and It won't pump enough air to shut it off. The compressor was supposedly sent to Quincy 5-6 yrs ago for this problem and was supposedly fixed.
I need to identify it so I can get parts if needed Photos attached. Any help will be greatly apperciated .
Frank
C
Frank
I haven't tried to run it yet but the unloader tubes were not on it , I'll put them on. in the morning and see what happens
MacMcMacmac
canada
Looks like a 216. They don't put out a lot of air once they hit 100psi. If you are trying to get 150 or 175 out of it you will be frustrated. You might be able to find pipe caps that fit those uncovered valve retainer rings.
