Hey Guys,
I am new to the forum and need some help. I researched this through old posts first and could not find one that was having the same issues as me. I have a Quincy QTV--54E vertical from 2017 that has always been a good machine. I recently moved to another shop and this machine sat for approximately 3 months before being plugged back in( I was having electrician run new 220 lines). When moved it was kept vertical and did not fall etc.... I plugged it back in and can't seem to get it to work. The Baldor electric motor comes on, turns the drive belt but the compressor makes a sort of hollow thumping and never actually cycles on. The electric motor continues to run for approximately 10 sec, then I hear a slight click and it slows down for approx 3-5 before speeding back up. It does slightly increase the air pressure in the tank when this is happening but the compressor portion does not seem to cycle on. I have checked voltage at the plug, replaced air filter, replaced oil ......nothing seems to be working. Any ideas would be greatly appreciated.
G
G
