As a satisfied Quincy owner for over 15 years, I have to admit that today, the Quincy name isn't the same as it was 15 years ago. Back then, they only built commercial grade compressors. Today, they have sold out their good name and are producing home owner grade compressors that in my opinion, just don't hold a candles light to what made them famous for quality. Before you plunk down your hard earned money, look over carefully any compressor that you intend to purchase. Today, a 5 HP motor isn't the same as a 5 HP motor of 15 years ago. Seems that they have figured a way to over rate a smaller motor to being something that it really isn't. As for the "Made in China", there are some quality products coming from China, and there is a lot of ****. Keep that in mind and don't just assume that everything is bad from China. For the most part, the stuff that is **** is the stuff that was once expensive, and now they can produce it cheaply. The quality merchandise still has a higher price tag to go along with the quality.
PS..... if you want a quality Quincy, look for an older unit that has the pressure oil feed for the piston and bearings, and an oil filter on the side. Junk....
