I picked up a used Quincy Qt-5 last year and after some wiring work (PO bypassed the mag starter and went directly to the pressure switch) it's been great. However, this weekend it's developed an issue that I'll do my best to describe.
It started off as a short lasting screech which I assumed was the belt. Now, as it increases pressure (say after 130 psi) it develops a really loud screech and it (the pump and motor) slows down and (it may just be me) but it seems like it is going to pop the breaker. I didn't let it get that far.
I did a visual inspection and felt around, the motor was hot, nothing smoking, no weird smells, etc. I checked the oil, it's where it should be.
I fired it up again and in trying to isolate where the screech was coming from I pushed on the back of the motor and the screech disappeared.
The belt is good and it's not loose. There's very little play in the belt.
Because I was working on a different project I didn't do anything else with the compressor.
I'd love your thoughts on this. I hope my explanation was clear.
Thanks,
Brent
Thanks,
Brent
