Quonset hut build
joshua4511111
I'm going to erect a quonset style hut which I will be using as my residence. The question I have has to do with attaching 2 X 4's (horizontally on 16: centers) to the building (steel master building) for nailing up wallboard. The way steel master indicated that the wood would be attached was using a coupling nut, threaded rod, countersunk holes in 2X4), addition nuts, cutting off excess threaded rod etc. Bottom line, it would be VERY labor intensive and I expect will take 20 minutes to make one attachment of the wood to the metal arches...(the building will be 32 X 70) Considering that it will take AN HOUR to attach one 14 ft 2 X 4... THATS A LOT OF TIME, EFFORT AND ENERGY. Does anyone have any suggestions at to how to efficiently attach 2 X 4's (horizontally every 16 inches for attaching wallboard). Surely somebody on this forum has 'built out' or had some type of 'finished walls for these steel buildings.
Zeke
You can do this in few ways. A few ways to do and a few different ways to do what they suggest. Allthread will save you a small amount of money, but buying the right carriage bolt in bulk won't cost much more. Use multiple drill motors set up for each operation and work off a rolling stage you can pull yourself along. Shouldn't take even 5 minutes per attachment.
Now, about different ways to do this: maybe self tapping hex head sheet metal screws will penetrate the steel. Sometimes you have to pre-drill not just a pilot hole, but one almost the size of the screw. Manufacturers can give you testing resutls.
In any case, start your hole with a spade bit to get the countersink you need. You can buy stops for these bits. Use the pilot hole produced by the paddle bit to start your pre-drill hole. With self tappers, you could get by with 2 drills and an impact driver or 3 drills. I think 3 drills total will do the bolts or alltread too.
Use corded drill motors when you can except for short easy-load drilling like the countersink. Lots of torque and they run all day.
Now, the question is, how are you gonna hang that drywall? I think the firring strips are the lesser of the two jobs. Most likely you are going to go with 3/8ths slightly damp and do 2 layers. I guess you could use 1/4" for the top layer. Be sure to stagger.
For a bullet proof job, one-coat tape the first layer. Skip the screws.
J
joshua4511111
actually I am thinking of wetting the back of the wall board (damp NOT superwet) to facilitate bowing or bending the board. I would wet the board, suspend it between two 8 inch cinder blocks and allow it to "bow' or curve' approximately what I will need. Will nail into the 2 X 4's but not SET the holes for filling in with joint compound. After drying for day, should be able to set nail heads and tape and float.... I HOPE. wish me luck and thanks for your input on attaching the wood to metal building
Garage Dog
Minnesota
I may have misunderstood about setting nail heads, but I would not be using nails to rock a curved surface. (or any other surface other than edges and corners)
Sheetrock screws have 10x the holding power after years of expansion and contraction.
TurnipTruck
Southcentral Alaska
I used several hundred "Z" sheetmetal brackets to space the 1x4 lath 8" in from the peaks, but I put on panelling or pegboard (or aluminum sheet over the weld bench. The lath is carriage bolted to the Z brackets.
