alan camby
Title says what i want.
I am kind of a newbie when it comes to milling machines. I have one of the table top Taiwan built milling machines that uses a B size drive belt. The speed settings start at about 130 rpm. My drill press goes down to 250rpm and has the small 3L size belts that like to slip under load.
Anyhow, I want to put some kind of drill style chuck on my mill for using hole saws. Every Hole Saw 1/2" drive mandrel I have seen uses a Hex or triangle drive design so that a drill chuck will grab the flats of the arbor.
From my school of hard knocks I have learned that some, If not all, key less milling drill chucks don't like to grab anything but round tooling. The 3 lobes don't seem like they are designed to grab a hex or three flat drill bit. Well all my drill bits have the 3 flats on sizes 3/16" and larger.
What is a good cheap R8 adapter to drill chuck taper or thread?What are my options on chucks that can drive the hex? Is this my best option for putting a hole saw in a mill? Don't really want to buy annular cutters for the mill. I see all kinds of cheap china r8 adapters to a key less drill chuck on Ebay but don't know if they will grab a hex.
Please don't get to fancy with the terminology as I will get lost quick. Seems to be a bunch of different tapers, collets, collet holders, ect. Right now the only thing I use in the mill are the cheap collets that go up in the R8 taper and are pulled tight by the draw bar.
Thanks,
Alan
Thanks,
Alan
