sierradmax
I've seen alot of really nice garages with race deck installed but in immaculate garages. My garage is a working garage with welding, spilled fluids, etc. is it worth $2000 to install this type of floring in my garage?
wythors said:I have had Race Deck for about a year now. Spilled fluids are no problem. Oil, transmission fluid, gasoline. None of these have harmed the tile. I haven't welded on it, so I can't comment there. The only problem I've encountered is that jack stands cut into the tile and the wheels on my floor jack dent it when supporting a car. I've gotten around that by using 1/8" aluminum plates under the jack and jack stands. For the amount of stuff I do, Race Deck is great. It gives me a clean, comfortable place to work on my cars. If I was doing much more, I'd probably go with epoxy for durability.
mikeyr said:I love my racedeck floor !!!
I have had a few dimples put in from heavy small castered items but the dimple goes away in a few days (weeks if cold).
dboat said:Mikeyr,
thanks for that last comment.. I did buy jack stands with pads on them for this very reason.. I plan to do this soon, most likely, this spring..![]()
Dana
dboat said:very well put.. I have been thinking and thinking about a Racedeck floor.. this post may just put me over the top and get one.. thanks![]()
Dana
:blush:batmbl said:I agree, esp. after getting a look at wythors floor.
tah81 said:I asked the vendor who sold me my Race Deck about the Moto-tile at Costco. He said it was made by the same company but has more filler in the plastic that makes it less resistant to oil and solvents, and could stain. This could be true or just a bid to seal my deal...who knows.
I have read of folks who have melted the tile by welding on it, so I wouldn't try that.
. There will not be any stain resistance problems with either of the brands. The main difference is the pattern and variety of colors. Moto tile come only in black, white or grey.mikeyr said:Now for the bad...you can't weld on the racedeck, especially mig, all that splatter will burn holes all over the place. I ended up having to buy a welding blanket to protect the floor, its a pain to have to do that but at least I don't weld that often and frequently prefer to weld in the driveway anyway when I can.
Roadster said:Why don't you just temporarily remove the tiles in the immediate area where you are welding, and then put them back when you're done?![]()
I can't do that with my epoxy-coated floor!![]()
BoostAddiction said:In the US, many states outlaw studded tires, and relatively few people use them in the places where they are allowed. So I doubt if there is much experience here in the US with studded tires on Racedeck or similar floors.
I suspect you'll find that studded tires will tear up the plastic flooring if you drive on them. Perhaps during the winter you could lay down thin wooden or plastic slats or runners to drive on, then remove them during both summer weeks.
Or, if you can just use M+S-rated tires without studs, they will be fine.
zen garage said:I have had a tile similar to racedeck in my garage for a few years now and couldnt be happier. My garage is a working garage, a few resto's, lots of heavy equipment and lots of spilled stuff. the floor has held up great and looks as good as when it was installed. The floor is priced between motofloor and racedeck and made by sportcourt. I have a combination of their Daytona and Tylon.
Hiker said:Keep in mind for what you'll pay for a complete Race Deck floor you can get a high quality epoxy flooring installed that will add value to your house. A Race Deck floor is considered personal property and an appraiser will not give any value to it. IMO, comparing vinyl Race Deck flooring to a good epoxy flooring job is like comparing Pergo flooring to hardwood flooring. There's fans of both, but one if far better then the other in quality.
