Race Deck garage door edging
Ryan M
Maryland
Ran into a small problem when installing my race deck. I have a 2 bay garage with 2 separate doors. 1 door sits 5" back from the other. It was an addition done years ago. I had bought the edging pieces, but I need to cut a tile for one of the doors, and that leaves no way to interlock the trim edging to the tile. Hope that makes sense.
Should I look at other options for the ramped part? Anybody had to deal with this?
Thanks
Ryan
CSRPenFab
Meridian Idaho
Thanks
Jennifer helped me out.
Can you share what your solution was? I've got a similar issue with my 3 car garage. The single car door is set back about 16" from the main 2 car door. I've got 13 boxes of RaceDeck tiles waiting to go down once I get around to it, and the edging on the 1 car door was one of my concerns. Thanks!
Garage Flooring
Grand Junction, CO
Keep in mind every design and situation is a little different. Sometimes you can offset a tile. Other times you can trim the front tile from the back and other times you end up using a piece of diamond trim. Your best bet is ALWAYS to call the manufacturer of your tile and let them work a solution with you.
R
Ryan M
Maryland
I ordered a 4" rubber transition piece. It comes in a 12' section. I will post pics once I get it. Only ordered for 1 side and will decide if I am doing it on both sides.
PAndaemonium89
reviving thread....any update photos on this transition piece? where you got it?
R
Ryan M
Maryland
This is what I bought. I’m pretty sure it was from Racdeck but it’s been a while. I glued it to the concrete. It has come loose occasionally, but I just glue it again. It just overlaps slightly.
