Race Deck with arched line
kabinenroller
S.E. Wisconsin USA
I have an area in my shop to display my microcars and motorcycle, it is presently tiled but I would like to remove the tile and install Race Deck. The area is bordered by three walls with the remaining area open to the rest of the building. One of the side walls is shorter in length than the other wall, the existing tile is cut in an arch between the two ends of the walls. The RaceDeck should have a sloped transition so that it is not a trip hazard.
Am I asking for the impossible? Any other options?
Here is a photo of the area, the wall on the left of the photo is longer by about 2’.
Thank You!
CombatNinja
I don't see any reason you can't cut the RaceDeck in an arc provided you have a way to do it. The tiny pieces may not hold real well if they have minimal engagement with adjacent pieces. I almost feel like it would need some kind of trim custom bent in an arc to properly hold that edge. Maybe the RaceDeck guys have seen this done somewhere?
Also, does it have to be on an arc like that? Might be better off with a straight line at an angle so you could use the RaceDeck edge trim?
K
kabinenroller
S.E. Wisconsin USA
Thanks for the reply.
I know that what I am asking for may be impossible or very difficult, but the arc on the flooring makes a big visual difference. A straight line between the ends of the wall will not work well because I have a small cafe table that fits in that area. If nothing else I will pull the existing tile and install new tile in a color other than black and white.
RaceDeck1
Salt Lake City , Utah
I wlll look for some photos of customers garages that have unique cuts/curves. After you cut the floor, you can **** up to the other cut for a seamless look, though will not be locked... should not be an issue on a full size floor stay in place
K
kabinenroller
S.E. Wisconsin USA
Thank you for the reply Jorgen.
I appreciate the personal attention to my inquiry. I would enjoy seeing photos of other unconventional installations.
CombatNinja
I'm taking this to mean that he is only going to put RaceDeck where you see the checkerboard tile in the photo and the rest of the garage will be concrete.
larry4406
Northern Virginia
Maybe something like this?
nolimits76
Oklahoma
Are you open to a segmented curve?
The chart view above illustrates how spacing and radius plays into how well a segmented curve does or doesn’t work. The first two segments are near curve but straight angled lines. The third is more obvious because it has a tighter radius. The other way to control the 3rd segment would be to use narrower spacing.
FYI, the majority of bridge beams are segmented on “curved” bridges. Depending on the exact radii, sometimes the beams will be segmented and the deck is formed and poured on a radius creating variable width overhangs but many times the deck is also segmented. Most people don’t notice because of the spacing and radii used.
You could control some of these factors. For instance your existing pic looks like 12 tiles wide. I assume those are 12” wide tiles. I definitely would NOT use the wider 18” tiles for your new Racedek as it would work against you. And I might consider a free flow tile as it has the optical illusion of being 6” wide. Also if you kept the radius but made it more flat then the segment would also look smaller.
I would use a free/trial CAD software to lay things out with your specifics to see what works or doesn’t.
Also I know you like your setup but having an open mind might yield a design you like better. Below is one example where it would be easy to visibly separate an area (also shows the effect of the free flow tiles I mentioned earlier).
If you end up with a hard transition I would consider a brushed aluminum plate or possibly a black diamond plate transition cover. It would add some interest and look cool IMO. Black diamond plate with stainless torx head recessed screws may have a particularly nice effect.
