Been researching Racedeck.
In the middle of the left side of the garage floor, I have a clean-out plug that sticks up a little bit (maybe less than about a quarter of an inch) from the concrete floor. If you step on it, you can notice a very slight bump. Has anyone with Racedeck encountered similar thing in their garage?
Will this cause a problem if I just lay the racedeck right on top of it? I figure if I ever need the plumber to check the cleanout drain in the garage, i can just temporarily lift out that section of racedeck.
The car tire will never drive over that part of the floor (it would end up right underneath the center of the car), so how much of a "bump" would I be looking at?
Is the underside of racedeck recessed a little bit from the sides or is the grid on the underside even with the edge of the tile?
