I have a 3-car garage with wall-to-wall white Racedeck XL on top of a concrete slab. One of my cars developed a very slow fuel leak (one drip a minute or so) and the gasoline ran through the inter-tile gaps and spread out under the flooring. This caused about 20 tiles to warp, raising the corners significantly. So, I have a few questions:
1. Can the warped tiles be saved? It appears that the effect of the gasoline is to expand the surface it is nearest to (i.e. in this case the underside) so I wonder if doing something like heating one side, or weighting the tiles in the opposite direction might permanently flatten them out.
2. Does the 15-year warranty cover this kind of damage?
3. Part of the reason it took me a while to fix the leak was because I couldn't find it, which was made more difficult by the fact that the gasoline immediately ran under the tiles at the nearest gap rather than pooling. Also if fluids couldn't leak below the tile one wouldn't have to lift them in order to completely clean up. This leads me to wonder about methods for sealing the inter-tile gaps. One obvious method would be to apply some silicone caulk to the gaps, but it's fairly laborious to get that down into the gap, especially when the gaps is as narrow as it's supposed to be. Any suggestions?
4. Unrelated to the gasoline leak, but... I find the "clop-clop" sound of walking on the tiles a little obnoxious, and it strikes me there might be an easy solution, namely, a periodic dot of caulk or similar material on the floor between the tile and the substrate. Or maybe an occasional quarter-size piece of thin rubber sheet. Anyone tried this?
