We considered doing an epoxy finish on our garage floor but in that respect were concerned, among other things, about the hairline cracks that appeared in the concrete and the expansion joints in a couple of places that open and close a little bit. (The floor is minimum 6 inches thick on a heavy base of crushed, compacted rock – built 7 years ago.) We were totally convinced that any epoxy eventually would be cracking on our floor.
Our investigations led us to the floor covering products like SwissTrax and Racedeck which, frankly, we believe to be significantly superior to epoxy finishes, though certainly more expensive. In the case of the SwissTrax DiamondTrax product that we chose
http://www.swisstrax.com/diamondtraxabout.html we feel it provides a much more attractive appearance; provides interesting colors and opportunities for different designs; is extremely easy to clean; is tough and resilient (withstands over 5,000 psi); can be easily repaired if it were damaged (just replace the damaged tile); and can be removed and used elsewhere if one chose to do so.
The SwissTrax is
extremely easy to install. Where cutting was needed to fit around corners or other objects we used a radial saw or a heavy knife. Any type of saw would work quite nicely. It’s also very fast to install.
As far as the concerns that have been raised about using this type flooring, first of all we would not use an “open” surface style like the Sportrax line from SwissTrax for a garage floor. We think it would be prone to catching fluids and general dirt. In the case of the DiamondTrax it is a “closed” surface and the seams between the tiles are quite snug – we have observed water has a difficult time penetrating the seams and they’re certainly not open enough to allow grit, sand or dirt to go through. The SwissTrax itself will not grow mold or mildew and we have a very difficult time believing any moisture which made its way through to the underlying concrete would cause it to happen there. Also, keep in mind that the design of the tiles is such that any significant moisture (maybe from a flood?) that made its way beneath the tiles would still drain, although more slowly, as it would without the tiles, i.e. according to the slope of the floor. As we said, it’s extremely easy to clean and maintain! We just vacuum and mop ours. Walking on the DiamondTrax does produce a “different” sort of sound from a surface like bare or epoxy coated concrete. It’s a slightly hollow, muffled sound – not loud and certainly not obtrusive or annoying.
Some disadvantages of the DiamondTrax include the pattern being very hard on one’s knees when kneeling (use a pad) and it’s awkward to roll things with small wheels or rollers like the refrigerator in our garage.
By now you’re clearly under the correct impression that we’re very enthusiastic about and pleased with our SwissTrax flooring. You’ll find some pictures of our application here (click on the smaller ones to see larger versions):
http://edsandra.com/esgeneral/Garage1.htm
Best regards,
Ed and Sandra
