I'm very happy with my floor.... Great company, great product and fantastic service. Made in USA. I have the tuff-shield tiles and have found them to be practically indestructible.
Showroom 021 by rbonitz2000, on Flickr
Showroom 023 by rbonitz2000, on Flickr
Anyone live in Quebec and have a Racedeck floor ? I would like to ear from you , with our winter, is your Racedeck floor great and would love to see it in person . I just receveid my sample at home and still thinking about it. I have in the mittle of the garage a pit of 24 inch X 18 inch , on that trap I have a aluminium diamond plate, but installing a race deck floor around would make that pit lower than 1/2 inch. Anyone have picture with almost same installation. Thanks you !
ThanksHello members, if you have a floor drain (mittle of your garage) with your racedeck floor then post some pictures. Thank you!
Even though right now I am upset with myself because of my floor, I still would not have anything else in my garage. Upset because I had to weld up and install a new exhaust on daughters car over the weekend and MIG splatter damaged a few tiles under the lift, I am upset at not putting down the weld blanket first. When I weld is the ONLY time I think about my floor (and I obviously did not think yesterday), other than that its just a floor, hose it down when you want and smile as you look at it.
I'm looking into getting the flow-through flooring tiles, and after messing with the two test samples sent to me, the only bad thing I've found is that using a jack stand to hold up a F150 does gouge (but not completely puncture) the tiles. Means I'll have to put a piece of wood underneath.
My guess is you are using the angle-iron leg type jackstands? ( like this <^> ) What happens with many of these styles stands are the legs are very thin and act like a cookie cutter, even chipping concrete at types. Any solid flat piece under the stand will eliminate any issue with this style stand as its not the weight that is the issue. Second option is to use a Snap-On, Mac , Et style stand that has a baseplate built in it.
Thanks
why do you have to drag everything out to wash the garage ? In 10+ years of having Racedeck I have not done that and when I moved a few years ago, i took my Racedeck with me to the new house, the old garage floor looked as good as the day I put the tiles down. I find my Racedeck to be maintenance free, sure once a year or so I scrub it clean and if it was concrete I might not do that but other than its just a floor. A awesome looking one![]()
That is true and I had not thought of it. I would never install free-flow in my shop since I would not want to lose all the small screws/nuts/washers/etc. as I work on the car and drop them. Also I would not install the free-flow stuff since I don't have a drain in my garage, I have good slope and installed regular tiles and let the water go down the slope.Well, when you live in winter land you have to wash your floor constantly. With the free flow tiles, all the rocks, mud, and road grit work down through the tiles leaving a bunch of junk underneath. The only way to get at it is to drag everything out and wash it out.
I just can't see plastic holding up to the kind of abuse my garage will see.
Like i said, it has its place for sure. Just not sure that a wet and muddy shop floor is it.
Hi
We are based in Salt Lake City and I live right in the mountains were we can get north of 500" of snow a year. My garage has FreeFlow in the front area where we park our daily drivers all year long. FreeFlow is channeled underneath to allow debris, water and slop to flow through the underside. Most garages that are in these types of climates are slightly pitched as mine is and everything flows out the door. Because I actually wash my cars in the garage during the winter, I do not ever have a need to unsnap a section in the spring..it is already washed out. As for holding up to salt? with many millions of feet of modular flooring sold each year, I am not aware of a single warranty for a floor that had salt damage?
Cheers
Thanks
I've been playing with my sample piece today. I like it. Just worried about welding near/on it.
