RaceDeck Installation and Injury
danieldd
Southern Tennesseee
It was a HOT Saturday morning down here in the deep south. It hit 90 by the time noon rolled around. I got up early and started moving everything out of the shop. By 8:00AM my BIL and his wife arrived and he helped to move the remaining heavy stuff. By 9:00AM we were ready to lay down the floor. My wife and my BIL's wife kept track of the design and brought us the tiles and we set them and went to stomping and hammering. By 10:40AM we were done with the floor except for cutting the edge pieces along the back wall and fitting some pieces around the lift.
I was surprised as to how well and how quickly the floor went down. The nice thing about the floor was we had to shift it after it was down to make sure we had enough gap around the perimeter. This was relatively easy to do.
While the girls went inside to get lunch going, we worked on the back wall to cut the final pieces needed on the table saw. Now, I have used my table saw for a variety of things over the past 25 years. Never used the guard as I was confident in my cutting skills. I set the fence to cut approximately 2.5 inches off the first tile and right after I cut it, I got careless and the tile kicked back and the pointed edge of it hit me right below the rib. It hurt bad!
We had to stop for a moment until I gained my composure and cut the remainder of the tiles. Fortunately no lasting damage other than a hit to the ego and a nice and painful reminder not to be so careless next time.
All in all I am pleased with the flooring. I didn't put anything under the tile, so it is a little noisy, but I'm usually blasting Pandora in the shop so it is not a concern.
Here are some pictures of the shop floor and the resultant injury…..
LXCam
Nice floor, nice job and nice bruise. All around you did well at all three things, you should be proud. :p.
Sarki
NY-Lower Hudson Valley
Floor looks great, nice job!
Sorry to hear about the mishap on the table saw while cutting down a tile.
I had a very similar experience while using my Makita chop saw to trim down my tiles during install as well. After at I switched to my jigsaw and no more problems.
Sarki
Wondering if there was a specific reason you didn't install RD tile under the Maxjack?
Didn't feel like removing posts or something else?
I ask because I'm about to install a 4 post lift and was planning to go directly over the RD tiles.
D
danieldd
Southern Tennesseee
Not yet finished with installing around the lift. With a 2 post you don't want to install RD underneath it. With a 4 post I hear it is acceptable to have it underneath it.
Sarki
Got ya, makes sense as weight distribution different 2 post vs. 4 post.
A,axing how that RD transforms the entire garage. Looks freaking beautiful!
zeeway
South Carolina
Good job on floor. I love the way Racedeck immediately classes up a space.
I have used a tablesaw for long time...and every once in a while I get a wake up call like you did. Glad it wasn't worse. I may be preaching to the choir, but please always use a notched push stick that can push and hold the material down, and a second stick to keep the piece on the far side of the blade from flying.
D
danieldd
Southern Tennesseee
Good advice and warmly received. Thanks!
dubber
Canada's Capital
Ouch!! Nice work with the floor though, it looks great. When i did my cuts with both garages i only used my Black and Decker workmate with a couple clamps and a skill saw.
spudley
Northeast Wisconsin
Ouch. That floor looks great, that bruise not so much. As careful as I am, I also learned the hard way what a kickback feels like. Now I try to never stand behind the blade. As others have already said, always use a push stick or push pad.
I cringe when I watch these woodworking shows and how dangerously close some folks get their hands to that blade.
Glad you're OK.
Is some type of underlay recommended for noise elimination?
bullnerd
Jersey
Sharp looking floor. Nice job.
99% of the time kickback is from the fence being parallel to the blade, it should NOT be.
