Racedeck over epoxy?
Quijote
Greater Boston
My concrete slab was poured mid/late summer last year. I decided to wait until the spring to give the slab a winter to settle. After a very harsh winter, the slab in the unheated garage held up great. Looks new and there is only a very thin control crack from the front door and in about 12 feet. The floor is new and has a smooth trowel finish. Still, I think a quick diamond grinding wouldn't hurt. Have not officially tested for moisture, but since the slab is above grade and has a vapor barrier, I think it's pretty damn dry.
I'm starting to plan out my epoxy floor. I was originally torn regarding what to do, but recently decided I might as well do it "all": primer, base, flakes, top coat.
The garage (22'Wx34'D) will be used as a home for my non-winter sportscar, kids vehicles, workshop area (at the back) and my 2-post lift. I will not be doing any ******** wrenching like pulling engines (well, maybe once every few years), but I have have seen enough pictures of long-term epoxy to make me wonder if the floor will hold up well enough.
I am wondering if it may make more sense to just apply primer+base coat and then later on buy Racedeck Free Flow tiles as desired. I see those are about $3/sf, so it's a pricey proposition to do both, but I would like having the concrete surface protected underneath, while at the same time, having a quality, and nice -looking base floor that may not require me to tile the whole space. I could selectively tile just the non-workshop area.
Attached is a diagram I made showing my lighting layout, but it explains the space. All dimensions are internal.
Thoughts?
A_Pmech
IL
It depends on your durability expectations. I've found many people seem to have unrealistic expectations for epoxy floors.
Q
Quijote
Greater Boston
My question is why would you do both? Go with either epoxy, or Racedeck.
Well, I just explained the logic above.
Less concern about the epoxy providing that "pop" or any concern regarding it's durability. I would still have it all over the garage, so I don't have to racedeck the whole thing and I can do so with the cheaper racedeck. Plus if anything gets trough the tiles (which it will), there is an epoxied floor underneath.
bdamico
I'd probably urethane clear over the racedeck for good measure.
Q
Quijote
Greater Boston
Racedeck is cheaper that epoxy? How much does Racedeck cost these days? When I installed it the price was around $3 per SF.
By "cheaper racedeck" I meant that the free flow tiles are the cheaper tiles from racedeck, versus the more expensive solid tiles.
Bob C
I quickly read the title of this thread and thought it said "Redneck Epoxy" I better open a beer.
RaceDeck1
Salt Lake City , Utah
here is a good picture of a customer with both epoxy and Racedeck
