Racedeck trim?
JackOfDiamonds
Idaho (USA)
I'm contemplating race deck but I am worried about how the edges will look.
I know they have end pieces for the garage door or places you want the race deck to stop, but what about where it butts up against a wall? Are you supposed to use normal baseboard trim there to cover up the ragged edge? In my garage, I have a concrete curb there, so it might not be easy to put a trim board down.
J
JackOfDiamonds
Idaho (USA)
I thought you have to leave a gap to allow for expansion though? No way would my brain accept that if there's a big gap at the edges.
Shea
California
A 1/2" gap is required. You can't **** it up tight against immovable objects. If you can cut a board clean, then you can cut the tiles clean :) It's not something that stands out when looking at the floor. Some people do use baseboard, vinyl cove, etc. to tidy up the sides.
larry4406
Northern Virginia
I read here on GJ where folks painted a small portion of the floor adjacent the stem wall/curb black and then painted the stem wall/curb black. This makes the expansion gap “disappear”. This is my plan when I get around to installing my RaceDeck.
Alternatively, I’ve read where folks apply a trim to the stem wall/curb with a thickness greater than the expansion gap with the floor tucked under. This seems more like a PIA to me.
89MustangGX
Stanwood, WA
I brought a tile to Sherwin Williams and had them tint a concrete "stain" to match. After cleaning the concrete with TSP, I painted around the edges of the floor a couple inches in and the stem wall. It looked seamless and never bothered me, coming from someone who is very picky about things looking right.
larry4406
Northern Virginia
I thought about that. Won’t work for me. I will have a checkerboard pattern of blue and black.
Maybe I will have SW match the black. 🤔
CSRPenFab
Meridian Idaho
I had a blue and alloy 2’x2’ checker in my prior RD garage. I still painted the curb and about 1” of floor black. I just used basic semigloss house paint since it won’t get any wear. It still looked good, and hid the exposed concrete expansion area.
J
JackOfDiamonds
Idaho (USA)
Thanks for posting this picture. I guess this shows that if you cut the edge perfectly straight, it can look finished even without trim. I have been assuming the tiles would either have the tabs still sticking out, if you use full tiles, or would have a rough jagged / fuzzy edge from being cut, if you had to cut tiles. My question is how you got those tiles cut so perfectly straight. Did you use a special cutting tool?
CSRPenFab
Meridian Idaho
Those were cut face down on a table saw. Very easy and you get a clean cut.
89MustangGX
Stanwood, WA
I did mine the same way. It's been a long time for me now, but I believe at the time the advice was to cut face down, using a plywood blade, and to put the blade on backwards. As I recall it gave a really smooth cut with the occasional flashing (melted plastic) that just popped off.
custom_garage
Exactly what I did. Just like @89MustangGX I bought a gallon of black epoxy paint from Home Depot. Painted the bottom stem/edge of the garage and out onto the garage floor about 10 inches before installing our RaceDeck floor. Since the tiles along the outsides were going to be black it came out perfectly. I started on one side so the 1/2" gap is smooth since there was no tile cutting. I used a jigsaw on the other side and it worked okay, but I knew that I'd have my tool cabinets all along that side, so no need to be perfect. On the front wall I had exactly enough room to use their trim pieces (same ones used at the entrances). I had to cut a couple to fit around the bottom of the water heater stand and such, but the look is very clean overall.
BTW, I followed other's advice here and laid down landscape fabric (weed mat) to avoid the "clacking" sound when you walk on it. It still allows for drainage and also covers up any ugly on your garage floor that might be seen through the slotted tiles. Highly recommended.
kngelv
Detroit, MI
I'm starting to hate the clacking. Does it ever go away or get better?
Do you have pics of your floor? Did you put fabric down? I went with the FreeFlow because it is silent even without the fabric. A guy in my sub has the regular and you could hear the clacking. I did a test section with fabric and regular and it cut the clacking by at least 50%. I’d pull it up and put the landscape fabric down.
James
custom_garage
Is there a “spec” on what type of landscape fabric is best for noise mitigation?
I just bought some large rolls of black fabric from Home Depot. Works great. They have some on sale:
custom_garage
Per @kngelv, the free-flow tiles don't make as much noise. I used those under the vehicle areas, but I wanted to avoid losing tiny screws and such that I accidentally dropped down in them so I used the regular tiles around the work benches. Even if you do drop something down in the open tiles you can usually retrieve it either with a small pick like this or a magnet like this. Again, worst case, you can pull them up individually.
