JasonTell7
- Joined
- Nov 1, 2007
- Messages
- 10
Getting ready to do my floor, and and completely up in the air on Epoxy Vs Racedeck tiles. Just curious as to why you chose one over the other, and in the end, if you regret your decision?
I've tried Simple Green and Mr. Clean to no avail.
...snip... As for me, I've done RaceDeck-style tile twice now, and while it's better than a bare concrete floor, I think I'll try epoxy next time. The tile gets dirty with use, especially after a couple of winter seasons, and gets discolored from the tires where the cars are parked. ...snip.....
The staining is likely because you tried "Racedeck-style" tiles, I have had my Racedeck well over a decade and my tiles have not discolored. Under my 4-post I went with all white tile to reflect the light back up to my project and it was that way for a good 10 years with my daily driver parked underneath the project car most of the time. Next to the lift was black&white checkers and my wife's daily driver. None of the white tiles ever discolored from the tires. Now, discolored from welding or plasma cutting, yes they did that but not the tires.
I have to be near 15 years now with Racedeck, I should go look and see if I can find a receipt. Oh, and when i moved, i pulled up the Racedeck and took it with me, I did change the under 4-post from all white to graphite and yes it looks better, its not as bright but it was amazing how dirty the all white would get while changing out a gearbox or other work on the car.
Odd , I never said anything about that in this thread. Are you trolling me?Lots of bullsh*t being posted about RaceDeck. I'm on my second garage with RaceDeck, both heavily used for all sorts of work from engine building to woodworking. None of the issues a certain poster is talking about have ever happened to me. And, as a Engineer/Industrial Hygienist, your claim about mold growing on concrete below RaceDeck is utter ****. Mold needs a continuous water source and organic material to survive.
I have these in part of my basement and the grandkids love playing on them. If they fall down, the tiles are soft and they don't get hurt.Has anyone used their carpeted tiles? I'm considering putting them in my basement for the kids to play down there.
KNGELV - your story sound similar to mine. I just ordered Racedeck yesterday for many of the same reasons you discuss. Another thing about Racedeck... if I ever move, I can always take it with me.
https://www.samsclub.com/sams/util-...24-x-24-8-tiles/107930.ip?xid=plp:product:1:1
These tiles are some sort of rubberized material that won't be ruined if they get wet. Just unsnap them, take them apart and dry them out, then mop up the floor and lay them back down again. On the other hand, Racedeck tiles have passages underneath them so water can just run toward the drain so there is no need to remove them.My basement gets some water in it from time to time (not much) every time I put something down it gets wet and ruined. I figured the racedeck type carpeted tiles would allow it to dry under them and let it run to the crock in the corner.
Thanks for post mikeyr - you are a prime example of someone who really works in your garage... and has been for over 15 years on RaceDeck.![]()
Id like to use RaceDeck on my newly redone garage too. Essentially it's 32'X50' separated in half by a wall at the 26.5' mark. Are there any discounts available for this? Factory seconds that can be used in the heavy use areas more likely to get damaged if at all? Anybody know what an approx cost would be for a two color checkerboard pattern?
Jeff
I live in the mid-west where we drag in salt and sand that ends up on the floor when the snow on the car melts in the garage. This does really add up over the winter months. I saw that the RaceDeck Free-Flow is recommended in areas with harsh winters and wet areas. Wouldn't this just drop the salt, sand, dirt below the tiles and create a mess that can't be cleaned? Maybe people spray it out over time, but this doesn't really get it clean in my opinion. Anyone have any experience here? I'm leaning towards the epoxy for my application.
BAd ***! Im bout to install my lift to put my air cooled up top! and wst on bottom. Seriously considering this racedeck! my garage is so hit up with oil and grease stains about 60 percent of the floor, my concern would be the apoxy sticking. I know i could spend countless hours steam cleaning and pressure washing etc to try to get it clean but Im not up for that currently.Installed Race Deck in my 800 sf garage. Put down some poly weed mat underneath it. Built my race car in my garage with no issues. And if I do spill fluids, well, one can lift some tiles and clean it up. After a number of fluid changes, haven't had an issue with that. No mold. No damage from floor jacks or jack stands.
See my threads below.
For a home garage, Race Deck works... For a commercial environment, like a dealer's 10,000 SF environment, there may be other options to consider.
