Racedeck with 2 post lift?
buddha2364
Missouri
So what is everyone doing with the flooring and 2 post lifts? I'm seeing pictures where it looks like posts are being set directly on top of the Racedeck flooring?
Garage Flooring
Grand Junction, CO
Lifts are used with RaceDeck all the time. Zero issues. Type of lift and how it is being installed dictate if it goes above tile or if you tile around it.
buddha2364
Missouri
I realize they're used all the time, but was surprised to see 2 post looking to set on top. 4 post I can see, as you're spreading the load out. What I'm more interested in is the arm swing-out clearance. Not that the flooring is an inch thick, but the low profile ones sit pretty close to the floor, and building the floor aournd a lift may get a little close.
Garage Flooring
Grand Junction, CO
If the lift is going to be in the same spot or if it is fixed I would put the tile over the base. If the lift is going to move or be moved you go on top. There are some exceptions. Typically I look at the footprint and go from there.
if I am missing something I apologize. When you have a model number pm me
RaceDeck1
Salt Lake City , Utah
WIth 2-post you generally install the post directly on concrete then trim RACEDECK around. With 4 post, you would just place the lift On Top Of RaceDeck
Screen Shot 2022-03-11 at 10.12.33 AM.pngScreen Shot 2022-03-11 at 10.14.17 AM.pngUNADJUSTEDNONRAW_thumb_12192.jpg
RaceDeck1
Yes it's a QuickJack, really a great system and can be portable too! if you don't have the space or the budget for a full-size lift, they are great
DirtyV
I cut around my 2 post lift but I'm not sure if it is an ideal solution since the lift arms now rub on the flooring when fully lowered with the lock disengaged. I'm trying to find a solution. I don't think setting posts on top of the tiles is a good idea...
