Im trying to figure out what circulator pump I need for my radiant floor. I have a 32'x41'x6" concrete floor in an older red iron building with the 12" insulated panels that lock together. The building has 10ft high walls with some Batt insulation and a tin roof. The pex is about 3" below the surface. There is 2" insulation under the concrete with a vapor barrier. There are 4 circuits of 1/2" nibco oxygen barrier pex two are at 150ft and two are at 360ft. I have a 105,000 btu propane crown cast iron boiler. I used the following website https://www.taco-hvac.com/uploads/FileLibrary/SelectingCirculators.pdf to try and figure out the pump size I need, but im having some trouble. I got 5.4 GPM with 32ft of head loss. So I was thinking about using the taco 009. Is this right or?
