Just starting to lay my 1/2" oxy for my shop floor, and i need some advice on a circ pump that anyone may have used and like. I have 8 loops of about 175ft each and 3 to add later when the mezanine is completed. I any help is great thanks.
To work properly, the circulator pump needs to be properly sized to the system, ie, what works for one system will not necessarily work for yours. Use the pump curves to properly size the pump. To do this you will need to know what your pressure (head) loss will be and the desired flow rate.
