Received a quote for radiant follow heating - the proposal is both for using existing boiler (creating a new zone) and a tankless water heater that would be mounted in the garage.
Question: If the radiant heat is not on in the sub freezing winter - what prevents the water in the in PEX / tubing from freezing? If they put antifreeze in the lines, doesn't fresh water flush through the tubes over time causing any antifreeze to lose it efficiency?
TIA.
TIA.
