maxpower_454
- Joined
- Aug 5, 2011
- Messages
- 58
Ok so I ordered my kit from blue ridge and got the stapler as well. My pad should only be 4-5" thick so they said it really wouldn't make a difference whether I pulled it up or stapled it to the floor.
My questions are:
1- Has anyone on here who stapled the tubing to the foam had any problems when the floor cracked (either at joints or elsewhere) and are you happy with the heat? Anyone use 2 layers of 1" foam under the slab? It's actually cheaper for me to go that way. Will the staples still stick ok?
2- How deep in the ground should I put my insulation on the sides of the slab??I can go 7" below the slab pretty easily and that will make the pieces I need about 12" wide which works out perfect. Is this deep enough? Also how thick should it be on the sides? I'm planning on about 2-3" of foam. Is this about standard??
Thanks in advance
My questions are:
Thanks in advance
