Radiant floor heat question
Cougar
Wisconsin A little south of the Frozen Tundra
Have an existing 30x50 shop, putting on a 24x42 addition.
The new slab will be pinned to the existing.
Was considering in floor heat for the addition.
My question is:
Will the 30x50 slab draw too much heat from the 24x42?
Thanks
larry_g
oregon
You can pin it and still have a thermal break in the joint. Me I have a heated and unheated area in the shop with no thermal break. Yes it looses some heat but not that much. It depends on how much efficiency you think you need.
lg
no neat sig line
kabinenroller
S.E. Wisconsin USA
I have 1,700 sq. ft. of my 2,400 sq. ft. Building heated with hydronic. There is a dividing wall between the two spaces that is built like the exterior walls. (2X6, vapor barrier, bat insulation, drywall) Under the wall I installed a thermo break of 2" ridged foam standing vertically. This stops all transfer of heat to the cold slab and cold to the warm slab. I also installed insulation and a vapor barrier under the cold slab to stop any moisture problems.
I am very pleased with the results.
Jim
BadgerBoilerMN
Minneapolis
My question is:
Thanks
Make sure the pins are smooth and coated.
No, not much heat.
BadgerBoilerMN
Minneapolis
Jim
Well done!
