Radiant floor heat supply temp
jrhaines2
I have a 32' x 48' shop with 1500' of 1/2 and am using a Takagi T-KJr2U.
What would be a good supply temp?
Currently my shop is 68 with 100 supply and 77 return and 2.4 gpm.The outdoor temp is 35 if that is of any interest.
tdkkart
Eastern Iowa
100* supply is fine, most recommend 100-120, and that mainly depends on how well your heat source works.
I'd turn down your room temp. Unless you're working in shorts, 68 is really warm in a floor heated space. If I run mine at much above 55* I'm plenty warm in jeans and a long sleeve shirt unless I'm just sitting.
whytry
my 36x44 shop is heated with a wood boiler my supply is 120 return 80 it pretty much stays that way in all temps (below 35) room temp is 67
J
jrhaines2
[QUOTE I'd turn down your room temp. Unless you're working in shorts, 68 is really warm in a floor heated space. If I run mine at much above 55* I'm plenty warm in jeans and a long sleeve shirt unless I'm just sitting.[/QUOTE]
Surely you jest!
I really wish I were one of those people who could eat just about anything and be comfortable at 55* but a back injury early in life has hindered circulation to my legs and I need lots of heat to feel comfortable.
Thanks for all the replies.
